Is there a rule as to how many skimmers a pool should need?
Farrier
18
Three Rivers, Ca
Commercial pool about 40k gallons. Currently only has two. We are in the bidding war process with different contractors to completely overhaul this sucker. Same say 2 is all required while some have suggested adding 1 or 2 more
Thanks
For a commercial pool, I would want 4 skimmers on that pool.
I would do an Intelliflo pump.
Do you have a main drain?
If yes, are you keeping it?
What is going to be done on the renovation?
^^^ I just found my code for skimmers. 1 skimmer for 500 sq ft of water. I averaged the 2 different widths across the kideny shape and multiplied the length and I come up with 966 sq ft of service water.
So out of sight in the above picture is a large live oak tree that my wife will not let me cut down. I ended buying a LeafSkim bucket and modified my vac line into a return to use it. I rarely get any leaves settling on the bottom now. If I add more slimmers, will it help grab those leaves? I don't want to use the LeafSkim after rebuild.
Yes, I have one main drain and I have to keep it, but split into 2 of course.
This is my original thread. Prob shouldn't have started a 2nd. As you can see, my current skimmers are not truly skimmers, LOL
