Hi everyone,
First, I want to sincerely thank this fantastic community for the incredible resources and helpful discussions. I've donated to TFP, subscribed to the yearly pool calculator, and I'll update my signature with full equipment details as soon as possible.
Background: I recently purchased a home in Las Vegas featuring a 13,400-gallon in-ground plaster pool (house and pool built in 2021) with a connected overflow spa and SWG. I just had the pool drained, tiles bead blasted, plaster acid-washed, and then refilled.
Due to frequent travel, I plan to retain my weekly pool service to help with routine maintenance. However, my goal is to manage the water chemistry personally as much as I can. I've been learning the TFP method and am eagerly awaiting delivery of my TF Pro Salt test kit.
Here's the timeline so far:
Concern / Confusion: In preparation of receiving my test kit, I purchased liquid chlorine, liquid muriatic acid, and liquid CYA from Leslie's. However, the staff member at Leslie’s was very insistent that I should NOT add liquid CYA or muriatic acid at this point. She nearly refused to sell me these products, stating emphatically that after an acid wash, my plaster "needs time," and adding acid-based products could severely damage the freshly acid washed plaster surface.
This advice feels questionable to me. Conceptually, I can somewhat understand it—after all, an acid wash exposes a fresh plaster layer, much like new plaster. But does her advice hold water? Could my pool company's immediate addition of powdered CYA after refill completion have been a mistake? Have I potentially caused damage to my plaster?
My specific questions for you experts:
Thank you all so much in advance—I truly appreciate your guidance
- Wednesday: Tiles bead blasted.
- Thursday: Plaster acid washed, thoroughly rinsed, and refill started.
- Monday Morning: Refill completed. Pool company immediately added powdered CYA (approximately 16 oz, visually estimated), 2 gallons of liquid chlorine (unknown concentration but clearly liquid chlorine, not bleach) , and placed two chlorine pucks in a floater.
(I removed the floater shortly after, having learned here that it raises CYA.) - Tuesday: Pool service company added salt.
- Wednesday: No actions taken.
- Thursday (today): I added roughly 3 cups of 12.5% liquid chlorine because I had removed the floater, the SWG wasn't yet producing chlorine, and my test strip showed between 0 and 1 ppm FC.
- Does Leslie's advice have any validity?
Should I genuinely avoid adding liquid or powder CYA and muriatic acid right after an acid wash and refill? Is it possible that my pool company screwed up by adding CYA as soon as pool was refilled and that it may have damaged the plaster? - Is there anything I should definitely avoid doing once my TF Pro Salt test kit arrives?
I'm anticipating I'll need to adjust CYA, chlorine, and potentially lower pH with muriatic acid due to Las Vegas water conditions. Should I wait on any of these adjustments given the recent acid wash? - Any Vegas pool owner could let me know if I should be ready to make any other adjustments given the Vegas Water (summerlin west if it makes a difference)? Will Alkalinity and Calcium Hardness be most likely appropriate? I want to go buy whatever I may need right now while I wait for my test kit. I am not expecting having to raise PH, Mess with Alkalinity or Calcium hardness with Vegas water but who knows? If so, should I wait because of the recent acid wash?
- I would like to add Borate for the SWG protection, PH buffering and water sensation. When would be a good time?
- Salt and SWG Issue:
My Pentair Intellichlor currently shows a solid red light indicating "Low Salt - Off," even though salt was added Tuesday. I realize it might take up to 24 hours for accurate salt readings, but it's been nearly two days now and the salt used was pool salt that visually dissolved very quickly. Should I wait until my salt test kit arrives, or should I add more salt immediately? - Chlorine Dosage (temporary measures until SWG activates):
Without my test kit yet, I'm flying a bit blind and don’t trust Leslie's to test my water. Considering my pool's size (13,400 gallons) and the chlorine already added (2 gallons on Monday, and approximately 3 cups today), what amount of liquid chlorine would you recommend adding daily until my SWG kicks in? Should I temporarily put the floater back in? The current daytime temperatures here in Las Vegas are around 78°F (low 60s overnight). Temps were in the low 80s earlier this week but are expected to cool down to mid-60s starting tomorrow.
