Thank youIt is fine. Better is this at ACE.
Transchem Muriatic Acid 1 gal Liquid Mfr# 1335100001 - Ace Hardware
Professional Strength 31.45% HCL (Muriatic Acid), excellent for pH reduction in swimming pools or to clean and etch masonry surfaces, excellent for pH reduction in all commercial and residential pools.Find the ACID MURIATIC GAL at Ace.www.acehardware.com
Got the Taylor SpeedStir orderedDid you get a kit ordered?
Did you get a kit, or just the speedstir?Got the Taylor SpeedStir ordered
Oh jeez. Dunno. Ordered the $48 speed stirDid you get a kit, or just the speedstir?
No salt water generator soDo you have a salt water chlorine generator?
If Yes,
TF-100 Salt Test Kit
tftestkits.net
If no,
TF-100 Test Kit
tftestkits.net
Ok I bought the non SWG kitDo you have a salt water chlorine generator?
If Yes,
tftestkits.net
If no,
TF-100 Test Kit
tftestkits.net
Thanks.Yes, it comes with pH test.
Some like the other pH tester, some don't.
