I'll try to keep this short...I've got a Pentair Intellivalve Actuator that allows me to automate filling my Glacier Pool Chiller. Cleaned out the chiller basin to prep for firing it up for the first time this year, however, when I activated the Pentair Intellivalve via my IntelliCenter automation panel, I expected the path to feed filtered water to the chiller but I noticed nothing was happening. In looking at the top of the valve actuator, I noticed a solid Service light and a flashing red Auto/Off light. I cannot use either arrow to manually rotate the valve open. I killed the breaker to see if it would reset, but still no luck. Attached a picture of what I currently see. As a stop-gap I just pulled this valve actuator and put the manual handle on there so I could get the pool chilling.
Has anyone encountered this before? Is it a lost cause? Will be significantly disappointed as this valve doesn't get too much use to begin with not to mention it was just purchased and installed sometime earlier 2021.
