Thanks to everyone for your replies
So, I read through the entire owner's manual, all the way back through the Warranty. On the Maintenance and Chemicals page under the heading of Water Sanitation, the second sentence (the first one simply saying to keep the water sanitized with regular maintenance) reads "Adding sanitizer and other chemical will control bacteria and viruses present in the spa water." Under the heading Maintenance of Spa Water and Cartridge, they say to "See your pool/spa professional for chemical, sanitizer, test kits and testing procedures questions" and "Use spa chemicals to maintain proper water chemistry." No mention of either chlorine or bromine in this section.
About 2/3 of the way down that same page, under the heading Water Chemistry Balance, the word chlorine is first used where they say to "Maintain the spa water pH level between 7.2 and 7.8, total alkalinity level between 80 and 120 ppm and free chlorine level between 2 to 4 ppm." Since chlorine is cheaper and generally thought of first by most people when it comes to pool chemicals, the fact that they say chlorine makes sense to me. There is a table on the page titled Spa Water Chemistry and Balance that is labeled "Preferred Water Chemistry Reading" where it gives the Minimum, Ideal, and Maximum preferred levels of Free Chlorine, pH, Total Alkalinity, Calcium Hardness, Saturation Index, and Water Temperature. The key word, I would say, is "preferred" in that table heading.
Absolutely nowhere does the paperwork say anything about not using bromine or having to use only chlorine. Had I not asked the gal on the phone at Intex about which chemical system they preferred, suggested, or otherwise recommended, I would not have given this another thought. The fact that she was in such a panic and had such clear instructions ("You have to empty the spa and refill it with fresh water and run it for at least
nine hours to clear out the bromine!"), makes me wonder what is going on. And that's why I'm here with y'all
I chose bromine because everything I read on "the Google" said bromine was better suited to the higher heat environment of a hot tub/spa. I really don't want to switch to chlorine, but I will if I need to. I just want to take good and proper care of the spa.
Thanks again for your time and guidance. I do appreciate it all.
Sue Ann
