Hello, we have fought iron staining in our fiberglass pool for years. Have done the Ascorbic Acid treatment many times, poured in way more Jacks Purple than called for and they just keep coming back.
We keep an eye on FC levels after treatment and it still returns even with all parameters close to optimum.
Tired of spending so much $$$ on sequestrant and poured the last remaining bottle in this Spring. We are having the iron start precipitating back into the surface worse than ever and even before our FC has stabilized really (after AA treatment). I am guessing that Jacks had been helping somewhat but this is a never ending battle.
Over the winter we finally put in a water softener with 3 stage whole house filtration but it’s as bad as ever or worse.
Is there any solution to filter the fill water enough to get the iron out? County Water from Wells.
EDIT: Not sure if the whole house filtration helped or the fact that we finally followed the procedure EXACTLY, bought a sequestrant test kit and adding a maintenance dose of Jacks Purple weekly. The iron stains have NOT returned in the slightest (but neither has the chlorine production in the SWG). We have an IC20 SWG and only a 7-8000 gallon pool and have cranked it up to 70% (usually much less is sufficient) and still adding bleach. We had to dump 4 lbs of Citric Acid in to get rid of the stains (way more than normal) but that should have been ate up long ago. SWG was replaced NEW last year and was working before the AA treatment. CYA is 70 and salt is 3650.
