I have an Intex 1200 gph Krystal Clear Sand Filer Pump, model SF80110-2.
This model has a built-in timer, but it will only allow you to run the pump for a set amount of hours per day continuously and then shut off. If the power goes out or it is unplugged, you can turn it back on and reset the timer, but it will be timed to run say 8 hours (or how ever many you set it for) from that time.
I have bought a Outdoor smart plug, which works through wifi. I can set the timer to run pretty much however I would like for it to with this method, but....
I need to know if anyone knows how to bypass the timer circuit built into the cover of the filter. I had first thought I would just connect the black wire and the white wire coming into the circuit to a switch and just leave the switch always on (to be controlled by the timer function of the wifi plug), but when this pump is first plugged in with the factory circuit in place it must be first turned on so I'm thinking this will likely not work. Does anyone have any suggestions?
Here are some pics of the filter and the circuit.
