Hello, I have had my 18' X 52" metal frame intex pool for 3 years. I was ready to close it for the season and noticed one of the drain plugs near the bottom on the pool is dripping. I do not want to drain the pool because I have a well and would have to have water hauled in to refill. The water is too cold to get in to repair (50 to 55 degrees). Is there a way I can repair this from the outside? Is there a product used for wet/marine applications that I could try? I can't tell if it is the drain itself leaking or the seam around the drain. It is dripping. I am not experiencing any noticeable water loss in the pool. The ground is wet around the area of the leak. Looking forward to your advice. Thank you
