Hi there, I'm a new owner of a pool. It is a small 15' round x 4' deep pool. I have a Intex model 8111 Kyrstal Clear Deluxe Saltwater System. It is the SWG and filter pump all in one.
I hooked it all up and set the time to run for 3 hours per day. It turns on the filter pump and a minute later the "chlorine" light comes on. It runs for the programmed 3 hours and then everything goes into standby mode.
For some reason I thought the filter/pump should stay on and run 24/7? Wouldn't it be better to have it pump all the time circulating the water and cleaning it?
If 3 hours a day is sufficient then I'll just leave it be.
thanks.
thanks.
