I have been using these things on my above-ground pool for well over 10 years, I've replaced it once and have the non-copper one now.
It is not generating as much chlorine these days, it makes lots of bubbles. It is not an issue with the chlorine dissipating in the pool.
It is very clean and this is where I wonder if I could have damaged it. Left if filled with vinegar all winter, just filled the whole chamber with vinegar and capped in intake and outtake.
I'd like to avoid buying another one and wanted to know if I should just get another electrode or if someone has voltage information so I can check it going to the electrode.
Always had a 5000 gallon pool and ran it 2-4 hours depending on the heat, running it 6 now and getting less than I did usually just running it 2 hours.
edit: also I have had the salt level checked a couple of times this year because of this even though I put the correct amount in, levels were fine.
Thank you kind pool people for any help!
