Hi!
I just set up a new Intex metal frame pool this weekend. The filter pump has been running perfectly, no leaks or issues. BUT, when I turn off the pump, the air jet valve leaks. There appears to be nothing wrong with it. It is clean of debris and the seal appears to be fine, as does the o-ring. It's confusing since it doesn't leak when the pump is on. What do I do?
Do I have to put on the little black cap every time we turn the pump off?
Thanks
Thanks
