Hi,
I bought an Intex 16' x 32' above ground pool set that comes along with a pump and a sand filter a month ago.
Should I add another pump to this model of pool?
I am beginning to wonder if the supplied pump is able to circulate the whole water body. Theoretically it could. Volume of the water divided by liters (gallons) of water pumped per hour and leave the pump on for the required number of hours.
However, being the inlet (water flowing to the filter) is located by the side of the pool, some parts of the water inside the pool might not "move" and be filtered. I am thinking of buying a cheap submersible pump, immerse it at the bottom of the pool just to move the water around the pool.
This concern came because I have been doing the following daily and yet the water color does not get any better.
Bewildered,
Henry
- check the ph and chlorine free level
- on the pump 4 hours in the morning, and 4 hours in the evening.
Bewildered,
Henry
