Yes it works with the AquaLink the system I installed it on is 3 years old, but if you need to you can use the IntelliCom II adapter ($150.00) to use with older firmware.
This pump is a BEAST and I highly recommend it for the price difference from the #011018 VS model however this pump should be run with minimum 2 1/2 inch line to get the most out of it since that's what the unions are made for 2 1/2 (ID) or 3 inch (OD). Good Lord I want to see the 5 HP version in action.
Don't think this is overkill I recently did a rather radical upgrade on a Jandy system that was running a Jandy 2.5 HP for system filtration and cleaner and a 2 HP Jandy for solar. The results are phenomenal considering what we started with and I'll tell you just what The Beast is capable of.
The system had dedicated solar lines (Suction from bottom of pool with dedicated returns to pool only) and a Jandy 2 HP Stealth feeding 16 Fafco panels on the second story of the house straight above the equipment pad. (No Filtration)
The client wanted a super efficient system that would run the filtration, cleaner and the solar while filtering the solar water and cutting down on the electric bill.
I'll shorten the story as to what we accomplished, under the current solar set up the water was not filtered and there was no return to the spa from the solar. So the goal was to eliminate the solar lines and tie the system into the main system. We tied the solar into the main system but when the cleaner valve would be opened it would take almost full 3450 rpm in order to run everything, that's still less than the 2 pumps but not good enough for the client. MAS helped out as much as he could with suggestions but for some reason that 2" cleaner line was killing us, causing the system to run at 2700 watts without the solar running. When we disconnected the cleaner line system only needed 1400 watts to run filter and solar.
Now here's the radical part, we added an IntelliFlo VS #011018 and a FNS 48 filter on the cleaner line and used the old solar return lines for the cleaner giving it a dedicated filtered cleaner set up.
Now with the cleaner and the filter pumps both running they are using only 1100 watts combined
and only an additional 600 watts in solar to pump 70 GPM up to the second story and feed the 16 FAFCO's.
The pool stays absolutely immaculate with the dual skimmers and The PoolCleaner handling the bottom duties.
Simply Awesome!
Sorry for the long winded reply.
