- Jan 30, 2013
- 10
- Plaster
- Pentair Intellichlor IC-40
Might be a dumb question.
The Intellichlor power center manual tells me it needs to be wired on the same circuit at the pump through a pool timer so it only operates when the pump is on. This makes sense,
However I am setting up with a new Intelliflo 3 which does use an additional timer. I also was under the impression the generator would not work if the was no or insuffcient flow through it.
How do I get around this?
