Greetings!
I believe this is my first post, but I have been reading the Forum for a few years now.
Thank you for all the wisdom shared!
We purchased our home with a 18x36 oval pool with a hopper near the end of 2020 and didn't open it until the season began in 2021. It came to us with an older, faded liner sagging from the beading in areas and a rip above the water line of about golf ball size and several extensive wrinkles. However, the pool had and continues to have integrity on holding water
. Other than what I mentioned, we had to replace the pump motor. My kids were eager, so we opened and balanced the pool. Due to its age, seeming a bit on the brittle side, and thinking we would replace it the end of that season, we didn't attempt to "warm and stretch" the liner back into the beading.
Fast forward to now. The liner still has integrity, still sags, still has wrinkles and the crack, and it is still faded.
Every year we say we are going to replace it. I think this may be the year.
So my first question is: When? End of this season or beginning of next? Or perhaps immediately? Our water is so nice and warm though...
I have read thicker is better: Any other recommendations of brands or vinyl?
We were thinking we would go through the local Aqua Leisure as the old estimate seemed to be a decent price... but what did I know at the time. Should we steer clear?
We live in Virginia in the Great Dismal Swamp area. Are there any considerations we should make as we replace the liner in regards to the higher water table? We did have times where areas bubbled up. Always the areas that had wrinkles. And always settled back down.
I could not find one, but is there a wiki for steps in this process that we should be aware of... a check list of sorts... best practices?
Thank you for your help.
