Increase Max Temperature on Jandy Pro Series Heater
I am trying to override the max temperature on my spa heater. Currently the max is 104 but I’d like to get it a few degrees higher. Anyone have any suggestions for a solution to this?
thanks
J
UPDATE: I figured it out. Quite easy actually. I just went into my Temp Calibrate setting on my Aqualink Remote and lowered the current temperature by 2 degrees. Now when I set my spa or pool temp it will always be 2 degrees higher. Simple :D
I don't believe this trick actually works it may be a little warmer but I believe if you put a thermometer in the spa it's only going to 104. Even though you are controlling the heater from the iaqualink the heater still has its own water temp sensor and will cut the heater off when it thinks the water is at 104 regardless of what the iaqualink says it is.
The 104 is a FDA temp limit and is hard coded in the heater.
In all the years I have been in the pool industry I have only ever seen one stand alone hot tub that would let you set it to 106. It was a model from Japan if Im remembering correctly.
Reactions: 1poolman1
