I believe I have a clog in the main drain line. If I set my diverter to pull only from the main drain I lose prime. If set the diverters to about 80:20 skimmers:main drain, all is well. I've tested for air leaks at the above ground plumbing and valves and don't see anything causing air leaks when I'm at 80:20.
So, any good DIY tips for trying to remove a clog? I had the coping and tile redone last summer and have a feeling it could be some excess grout/mortar from that job combined with hair, leaves, etc. There are 2 drain coverings at the bottom, not sure what they look like under the covers.
