- Dec 10, 2021
- 33
- Plaster
- Pentair Intellichlor IC-60
Im a serious DIYer and I'm in the planning phase of building a 20'x40' 20x44 icf pool with autocover and SWCG. Going from 4' to 8' 3.5' to 8.5' depth with diving board. Trying to keep budget around 50k. Probably closer to 65k now at a minimum. Rebar and concrete are more expensive then I thought.
A couple years ago I built a 30x35 natural swimming pool / pond with upflow bog filter but its been tough to keep the string algae at bay and the wife would prefer a pool.
Design
Working with Pool and Spa Designs out of Scottsdale to help with some of the plans and parts lists and possible wholesale discounts although I have a wholesale contractor connection already.
Why ICF
I'm going with ICF for a few reasons: its DIY'able, insulation is a bonus, I can use my existing pond hole and not worry about it being overdug on the sides. I've poured lots of concrete over the years including flatwork and foundations. Planning on a monolithic pour using fab-form products. See icfguru.com and some of there builds. Challenge is the city requires stamped engineering and I'm struggling to find an engineer willing to help with an ICF pool.
Utilities
I already have a sub panel and power run for my pond so electric is ready to go but would need a long gas run if I want a NG Pool heater.
Heat
I'm thinking a pentair cool / heat pump will be the best route as it will save on utilities and the cost of running a gas line from the meter. (I already have a Pentair VSP). Not sure how effective a heat pump is though in Northern Utah. Summers get hot and the cooling feature would be nice lots of people in the area struggle to keep there pool cool in the summer. I realize i may not be able to heat much in the early spring and late fall. Autocover should help keep the heat in. Going with a gas heating for now.
Finish
I'm still contemplating the finish, likely will go with vinyl but I'm concerned about kids putting a hole in it. I will want to put something over the ICF to prevent denting like a base coat. I may splurge and go for plaster or pebbletec. If I go with a liner I think I will have budget for a separate spa.
Filter
I'm thinking a large cartridge filter will work best for me. I'm not sure what to do with salty back flow water if I were cleaning a sand filter and being able to use the hose to clean off the cartridge filter seams simple.
Other ideas
I plan on using a channel drain to reduce robot cleaner getting stuck on the drain.
Next Steps
Find someone willing to do the engineering (waiting on quotes) Engineering stamped and in hand
Get ICF and Fab-form materials Done
Get building permit from the city (summitted permit)
Drain pond and remove liner done
Decide on finish (pebblesheen if budget allows)
order equipment (autocover, diving board,)
Purchase pvc pipe
Purchase rebar
Excavate hole for pool Done
Geotech inspection Done
Deliver gravel for base of concrete (ordered arriving 6/17, they will have a "rock shooter" to spread the rock out)
Install floor insulation
Form up ICF
Brace ICF
Stub plumbing in ICF
Form equipment pad
Pour concrete
Gas line to equipment pad
Electric line to equipment pad
Trench for plumbing
Equipment (updated based on suggestions)
Pump - Pentair 011018 IntelliFlo 3hp VSP (own)
SWCG and Automation - intellicenter w/ Pentair IC60 (purchased)
Filter - Pentair EC-160332 Clean and Clear Plus 520 Cartridge (purchased)
Heater - Pentair 400K BTU (purchased)
Lights - Pentair MicroBrite's x 4 (purchased)
Design
Why ICF
Utilities
Heat
Finish
Filter
Other ideas
Next Steps
Purchase pvc pipe
Purchase rebar
Form up ICF
Brace ICF
Form equipment pad
Pour concrete
Trench for plumbing
