IC40 Low Output Mode
BDY
802
Houston, TX
Pentair Intellichlor IC-40
On my new IC40 I have it set at 10%. All my sanitation lights are simultaneously flashing green. Written on the cell it says this means “Low output mode” but i can’t find anything in the manual or on pentair website to explain. Is this an issue or is it just notifying me I have it set low?
Thanks
B
It just means you have it set for 10%. The flashing lights is how the cell informs you that you are in the range from 2-18%. Once you set it at 20%, the flashing stops.
Reactions: BDY
If the LEDs are flashing then the top numbers above the LEDs show the % output...
If the LEDs are solid on then the bottom numbers show the % output.
Thank you! I am still lowering it to get to FC base for the spring but I’m assuming I’ll have to slowly ramp it up to 3-4 ppm a day in Houston summer…
