I Want to Block my Overlow Grate
PoolboyPedro
10
Peachtree City
I have this glued in grate to let out excess water but I don't want it draining my precious salt water every time it rains. I've tried to pry on it to remove it. I want to block it off. Ideas? Preferably something reversible/non destructive. Thanks
Pedro,
With the screws removed, it should just pop right out. :scratch:
I removed mine and then glued a 1" plastic 'patch' to the back side. This allowed my water level to go up by about an inch before it went into the overflow.
Reactions: Mdragger88
From your pic, it appears there is grout in the area around the perimeter of the cover. Try removing that with a flat blade screw driver - carefully.
Here is an adjustable cover so you can vary the water height.
