I replaced this Multiport valve ( the old one lasted probly 10 years. Anyway, over the last several months there seems to be an air leak on the sand filter outlet side. When the valve is set to filter there is an audible "buzz" is the only way I can describe it. After several pump cycles air builds up in the sand filter and when the pump turns off the air pressure pushes back through the inlet lines to the pump and it sometimes takes a long time to reprime the pump and start pumping. If I run the water to any of the other valve outlets (recirc, waste, etc) there is none of the buzz. If I bleed the air pressure off the sand filter it runs fine for a few cycles. I've checked the star seal on the valve plate and it seem fine. The sealing surfaces inside the valve body seem clean and smooth. What do you think ???
