My Chlorine levels aren’t at their normal levels and I have cleaned my filter, but my pool water has a green tint to it. How can I correct this?
The chlorine I use is Chlorinating Liquid with 10% Sodium Hypochlorite
my chlorine level is currently 10 I try to keep is between 8.0 & 10.0
my Ph level is at 7.2 right now..
those are the only 2 levels I have been monitoring
Ok my CYA level is above 100....what is my next step and what is my desired level?You do have a test kit?? Which one? Please get us:
FC
CC
pH
TA
CH
CYA
Salt (if applicable)
Then we may be able to spot the problem.
Do you brush your pool? Robot goes up the sides??
Maddie![]()
This is good.The chlorine I use is Chlorinating Liquid with 10% Sodium Hypochlorite
Why do you "keep" it at that level?my chlorine level is currently 10 I try to keep is between 8.0 & 10.0
This is low.my Ph level is at 7.2 right now..
How are you testing CYA? Are you testing it in the daylight with the sun to your back and tube at waist level?Thank you. I will try to do a CYA test now
What mknauss said. A water exchange.Reviewing Extended Test Kit Directions Archives - Trouble Free Pool will help you get accurate testing.
CYA tests need to be done in full sunlight, with the sun to your back.
You will most likely need to drain/refill or exchange 50% or so of your water volume, depending on a final accurate CYA test.
