I accidentally wired a new raypak 336a to 120v instead of 240v. (I know that's dumb) Everything went blank after a couple minutes. Tested the transformer (bad) and replaced it. Replaced the 5 amp fuse on the pc board. Output on the new transformer is ok. The display is still blank and nothing comes on. Is there a way to test the pc board? Is there something else I should check?
