Pool was replastered, and today (Dec 14) is 13 days after the 2-day fill ended. I am trying to follow the NPC guidelines, which the plastering company approved of, regarding brushing and balancing. My main concern is to prevent any problems/damage to the new plaster, especially maintaining a smooth floor in the shallow end. Kids were getting bloody feet this summer from the previous rough surface (it's a relatively new house for us, and is our first pool).
Here are the current chemistries using TF-100/SpeedStir:
FC 2.5 (maybe 3.0, a little hard to tell which is correct) I usually use liquid chlorine, but may mix with Trichlor pucks carefully to avoid too much CYA.
CC 0
CH 200 (should raise, but to what level for new plaster?)
TA 80 (what is ideal now?)
pH 7.6
CYA ~10 (still see a very faint dot at 20) (will be raising CYA to about 30)
Water temp 49F
CSI by PoolMath: -0.46 (presumably this low mainly due to low temp?)
We don't plan to swim in it until next spring, but I want to do what's necessary to keep this new plaster in the best shape possible.
I know I should raise the CH somewhat, but I don't want to go overboard.
My TF-100 laminated sheet says 250-400 is ideal, but the Recommended Levels in Pool School say 350-550 is ideal, so would like to hear what the current suggestion is considering this is New Plaster. And would this change later after the plaster has fully cured?
NPC recommends CH at minimum of 200 for first 28 days and 200-400 afterward.
Ideal TA level is also a question I have.
My TF-100 laminated sheet says 100-120 is ideal, but the Recommended Levels in Pool School say 60-80 is ideal. These are quite different ideal levels.
NPC recommends TA at 80-100 for first 28 days and a "Carbonate Alkalinity" (CA) level of 80-120 afterward. CA = TA - (1/3)(CYA).
Is CSI anything to think about now, or is the cold water throwing that figure off too much?
Thanks for suggestions on what levels I should adjust to for new plaster.
CC 0
pH 7.6
Water temp 49F
