How to Calibrate mu Salt Water Generator Salinity Sensor
RESISTENCIA13
189
Scotch Plains, NJ
Jandy Aquapure 700
Hi! How can i calibrate my salt water generator Salinity Sensor? I pool company tested my water is told me my salinity is 2600 ppm however my SWG shows me salinity at 3300ppm, which i do believe to be wrong as i had not added salt since pool was open in may and levels have not drop. So i know sensor readings are incorrect.
  • Press the “Salinity” button and hold it until it beeps 3 times. The system will beep when you push it and then at 5 seconds and again at 10 seconds.
  • Release the button after the 3rd beep. Press and release the “Temperature “ button within 5 seconds to enter the salinity calibration screen.
  • The system will display the salinity reading, press the up arrow to increase the reading and the down arrow to decrease the reading.
  • When the proper reading is reached press the “Temperature” button within 5 seconds to store it in memory.
