How tight to make winter cover
Bosley
0
267
Edmonton, alberta
First time winterizing and the only thing i am not sure on is the winter cover. I cannot determine if the winter cover should be tight across the pool or hang down on top of the water. I would thing to let is loose and hang down but i have seen pools in my area where the cover is trampoline tight. I do not want to damage the pool by making it to tight. I have read many posts about hanging bleach bottles etc to help keep the cover from blowing off.
Cheers all.
Let it hang down into the water. Since it will collect water & snow anyway, add an inch on water on to to keep it from flapping around. Many people put inner tubes or “pillows” under the cover to elevate the center.
I wouldn’t make it trampoline tight since it can damage the walls from the weight of snow above. Rain might run off, but snow won’t.
Reactions: Bosley
