Hi,
I live in TX and it’s been a crazy hot summer with consecutive 105+ degree days.
I’m only on my 3rd yr off pool ownership and am confused as what to expect on how often I need to check and add stabilizer. Almost everywhere, you read that stabilizer NEVER breaks down and water must be diluted to lower CYA levels. If this is true then how come I have to maintain my stabilizer levels over the months/years?
I found this thread (Can't keep my CYA levels up Texas heat is making me lose my mind) which says I should expect to lose 10 ppm over a month or two.
I’d just like some clarification on what is correct in case there’s something wrong with my pool chemistry. Also read that ammonia can be an issue if you can’t maintain chlorine levels.
At the beginning of this summer, I balanced my CYA to 40 ppm. It’s been 3.5 months and I’ve rechecked it and I’m now down to ~20 ppm (this is a guess bc the Taylor kit doesn’t go below 30).
Also, I have to add 1 gal of 10% chlorine to the pool every 1-2 days during the summer to maintain levels above 5 ppm. Is this also expected in this type of heat? Again, asking to make sure I’m maintaining things correctly.
