I have a spa/pool combo where the spa overflows into the pool. The system is a Hayward GLX-PS8 that used to be salt but was converted into chlorine. The previous owners at some point converted from two heaters to one heater that works for the pool and the spa. There are three pumps: 1.5hp pool filter, 1.0hp spa filter and 1.0hp water feature. Before we moved in a few months ago I had the pool checked out and the guy ran through how the pool/spa heating worked. I used it a few times but now either my instructions are wrong or it does not work correctly anymore.
Steps to turn on the pool heater:
1. Have it set on pool mode, pool filter is on
2. Adjust Pool Heater 1 to desired temperature
3. Heater 1 light will automatically come on and pool (and spa) will be heated
This works fine
Steps to turn on the spa heater:
1. Switch to spa mode (in this mode water is only moving through the spa)
2. Turn off pool filter
3. Turn on spa filter
4. Adjust Spa Heater 1 to desired temperature
5. Heater 1 light will come on and spa will be heated
Heater never comes on
Workaround or maybe how it is supposed to work:
I have found that if I leave the pool filter on, when in spa mode, then Spa Heater 1 will come on. But now I have both the pool filter and the spa filter pump running. That seems a bit like overkill on a small spa. Is this how it is supposed to work?
I have a few photos of the area and control panel but for the life of me cant figure out how to get all the attachments in here.
This works fine
