I have a long run (~130 ft) to pull a globrite wire. I want to use lube to facilitate the pull.
A couple of questions:
- What lube should I use?
- How should I use it?
I've done a bit of research and this is what I found:
I see folks recommending Liquid Dawn, others some 3M product.
I was assuming that I have to drop it in the conduit from the junction box, and then add water so it "pushes" the lube towards the niche/pool?
My run goes down and then back up again towards the pool, so I probably need to seal the feeding side to make sure the lube is better pushed past the lower section?
But then if Liquid Dawn isn't this going to create soapsuds that will make a mess on the junction box side? How do I make sure it reaches the other end of the conduit on the pool side? Liquid Dawn is going to be very diluted once it gets there and it doesn't really have any color I could spot. Perhaps a viscosity check with the hand is all I need?
If using a "real wire puller lube" such as 3M, is it an issue if too much of it gets into the pool? Health or equipment dangers?
Should I start the pull without lube and only add the lube once I start needing to exert too much pulling force?
Sorry for what it sounds like dumb questions, but I'm not able to find these specific answers on the forum or even the internet at large (google/youtube, etc).
Thanks in advance!
Thanks in advance!
