I've owned the house that came with this in-ground, fiberglass pool for 10 years now and have to confess that I've never really understood the plumbing enough to feel comfortable closing the pool myself. I am tired and broke of paying $400 a year to get the pool closed. I would like to blow-out the lines using my 5HP shop vac. What kind of adapter is needed to connect the Vac hose? I've seen about a dozen different YouTube videos online and no single one of them does it the same way or has quite my same plumbing. I've attached some pictures of my equipment, hoping maybe someone can give me some guidance here.
Below is the photo of my pool equipment while in normal operating mode. This is the position my valve is in when the pool is running. The other side of the valve is labeled VAC. I never use this setting. When I vacuum my pool I do it from the back hole of the skimmer and the valve remains in the normal operating-mode position as pictured here.
Here you can see the picture of the vacuum port on the side of the pool which I never use. Is this the one that goes to the Vac line I references above?
Below is the opposite side of my sand filter. The valve is turned to Jets. The other side is for Fountain.
Here is the picture of my skimmer. I use the back hole (One farthest from the Pool) to vacuum the pool.
Here is what my drain looks like below? Is this where the front hole of the skimmer leads to?
Here is my fountain
Some Additional Questions:
Where would I attach the blower hose to blow out the jets, vacuum line, main drain, and fountain and in what order and what changes do I need to make to the valves during the process? Finally, After pulling the plugs on the pump basket, sand filter and heater, do I need to blow water out of those as well or just let them drain and do I do this part last? I know this is a lot of information and there are so many different ways to do this. I think I would be fairly confident of getting the pipes winterized if I had a better understanding where everything goes and in which order to do things. Greatly appreciated!
Rob
Here is my fountain
Rob
