- Jun 18, 2014
- 654
- Vinyl
- CircuPool RJ-60 Plus
I should have replaced these when the liner was done earlier this year, so my bad.
Everything is exposed, I have replace all the pool line and found that the back side of the return jets is cracked and leaking. They are split and no amount of pipe dope, teflon tape, glue will seal it.
I know the liner has to be pulled back to do this.
I have new fitting already.
What tips and tricks are there to replace these? How far below the fitting should i drop the water? How difficult is it going to be get the liner back in the track (liner was put in in May this year)?
