I believe I have bed. Under monitoring my spa chemicals. I only check once or twice a week as spa is only used once a week normally and has not been used since May. These are the four items I use and usually test with a strip.
I have a test kit but never used it on the spa.
I want to change and would appreciate a outline of steps to take.
I have a 400 gallon hot springs 1994 High Life.
I used the test kit today and here are the numbers
PH 7.2
CYA 100
TA 60
CH 275
Chlorine was 0. I added 2.2 tablespoons of the blue lid sanitizer (is that dichlor ? Tri?)
When I change my water I use ahhsome
I look forward to your experience
Thanks
Kathi
PH 7.2
CYA 100
TA 60
CH 275
Thanks
Kathi
