Hi All -
So I took a shot at winterizing or 30k in ground a few days ago.. was able to get nearly everything buttoned up except blowing out the main drain, which my shop vacs couldn’t handle, but that’s another thread
. My concern is that I purchased RV antifreeze from Tractor supply (the description on the box mentioned pools and potable drinking water systems, so figured it was safe). I didn’t however confirm that the ingredient was propylene glycol. After putting a gallon in each of the 2 skimmer lines I looked again at the box and found that it’s ethyl alcohol based antifreeze. I’m wondering if I should attempt to vacuum out those two lines now and replace with the propylene stuff or just leave it and vac out on spring? Also, how bad out of curiosity are we talking is this type of antifreeze when mixed with pool water and humans are exposed to it? Doesn’t appear to be the really no no stuff (ethylene glycol) that I’ve read about, but what do I know - any recommendations and expert advice re how I should address this is very much appreciated! Thank you again!
