I know this is primarily a pool forum, but you all are always so helpful and friendly. Not sure where to post my question regarding my hot tub pumps and hardware type stuff. Please move it if need be.
We had an above ground pool (still showing in my signature). We have sold it and will be getting rid of it this weekend.
We have picked up a free SunDance Optima hot tub and have been working towards getting it set up and running. The previous owner told us it had been throwing a FLO code and he didn't want to deal with it, so we knew we had some work to do. We have poured a cement slab. We have installed the necessary electric hook up and breakers. We have placed the tub and started filling it up. We discovered a leak coming from one of the big pumps (assuming a jet pump). When hubby took it off we realized the shaft that goes from the dry end to the wet end was severely corroded and it broke off. We purchased a new Waterway pump and installed it. We proceeded with filling it again. We got it full and the heater came on and started working fine. The jets would all come on and the little bubble jets also worked.
We noticed right away the circulation pump would get extremely hot. Like you couldn't touch it hot. I watched the pressure flow valve (it is in a clear tube) and I could see it activate when necessary and turn off when necessary. I put in some AHHSOME cleaner and ran the jets and everything for 20 minutes. Then it threw the FLO code error. I turned all of the jets off. Turned them back on and the FLO error continued to show. I did notice, however, that the flow valve was no longer activated like it should be when the water is moving. So, I was thinking that I needed to replace the flow valve. However, since the circulation pump was overheating so much I got to wondering if I should replace the circulation pump instead. So, I drove the hour to the SunDance dealer and purchased a circulation pump. Brought it home last night for hubby to install it and he is questioning the amperage/voltage/etc (that part is all beyond my knowledge).
It appears as though the circulation pump has been replace before (the hot tub is a 2002 model, the pump had a manufacture date of 7/2017). The pump that was on the tub is only two wires and the pump we purchased yesterday is 3 wires. I believe the new pump is correct, but now we need to figure out what they did with the 3rd wire.
I think we picked up someone else's hack job, but we can fix it with the right parts and knowledge. I guess my question is......how do I know if it is the circulation pump or the flow switch? We have taken the circulation pump off, but have not yet installed the new circ pump. I want to make sure we need the circ pump and install it correctly so we don't fry it.
Is there further info you need from me to help answer my questions?
THANKS so much!!!
THANKS so much!!!
