- Jul 1, 2020
- 7
- Vinyl
- CircuPool RJ-60 Plus
Desperately trying to find a solution to this since there are no local dealers that will work on an Artesian spa.
Our hot tub stopped heating. We've replaced the display panel because it was fading and needed done anyway. After connecting to power it would display Pr to indicate priming and then show a wildly high temperature when it's actually like 65 degrees. Turn the jets on and the display rapidly climbs to 110 followed by an overheat warning or HFL indicating that a significant difference between temperature sensors was detected.
So we bought a new HQ heater assembly and replaced that. Again it's showing a temperature much higher than it actually is. Would also sometimes display 'dr' indicating poor water flow or bubbles in the heater. LED for Filter 1 2 also lit but I don't know what that means--both are installed.
Running out of ideas. Bad circuit board?
