After years of using the hot tub occasionally, we have made the decision to drain and close it indefinitely, possibly to be started up again sometime in the future. I have gone through old posts on the forum regarding how to prepare a hot tub for being empty long-term (and over cold winters), but I didn't find a case where anyone drained their hot tub and did not start it back up again after a few months.
Does anybody have experience with closing down a hot tub and what steps would be required to ensure it can be started up again at some point, without causing damage to the equipment? (Ex. does antifreeze need to be run through the pipes, do bleed valves need to be left open, etc.).
Thank you for your assistance,
Matteo
Hey Matteo,
I've had some experience with shutting down a hot tub for extended periods, especially over the winter. The key is to ensure everything is properly winterized to avoid any damage from freezing temperatures.
Here are the steps I recommend:
Complete Drainage: Make sure you drain all the water from the hot tub. Don't forget about the pipes and pumps—these need to be completely empty.
Flush the System: It's a good idea to flush the system to remove any remaining chemicals and contaminants. You can use special flushing agents available at hot tub supply stores.
Antifreeze: Yes, running antifreeze through the system is crucial, especially if you're leaving the hot tub out over the winter. Use a non-toxic, RV/marine-grade antifreeze that's safe for water systems and environmentally friendly.
Open Drain Valves: Open all drain valves and let any residual water escape. It’s also a good idea to leave the valves open so any leftover water can evaporate.
Disconnect Power: Make sure the hot tub is disconnected from the power source to avoid any accidental activation of the system.
Cover the Hot Tub: Finally, secure the hot tub with a proper cover to protect it from debris and moisture. If possible, use an additional layer of insulation to prevent cold air from getting in.
I hope these steps help you prepare your hot tub for long-term shutdown. If anyone else has more tips or experiences, I'd love to hear them!
Best, Brad
