(I hope I'm in the right thread...)
8'x8', two big styrofoam blocks that fold in half, then stand up with the help of a cover lifter.
The center seam (where it folds) has blown out starting at one end, and since the PO neglected
it rather than fix it while it was small, it's now extended 3' across and the edges atrophied and
pulled back. So I now have about a 1/2" gap to close.
Someone in another thread (predictably) said "duck tape". I - professionally - hate adhesive tape.
Over time the adhesive goes to Hades - gums up and turns into a gooey mess. Or hardens and
flakes. Or leaves some unidentifiable (and uncleanable) residue. And being outside, exposed to
water and sunlight and temperature extremes (around here, -40C to +30C) assures that it'll become
the worst it can, and the duck and plastic will just fall off and I'll be left with a bigger problem than I
have now.
I've used Tear-Aid on a tent, and it worked well, but is ridiculously expensive and not meant for
repairs this long. Are there any new tapes out there (Gorilla, maybe?) that have the strength and
longevity - as well as low-temperature flexibility - that this fix needs?
Thanks.
Jonathan
have now.
Thanks.
Jonathan
