Hi all!
I haven't posted in awhile so I figured I would post something I figured out. I had to pull the info from a bunch of different places and had to piece together the info so I figured having it all in one place might help.
Backstory:
I wanted an autofill when my pool was built. But due to my city permit requirements and some drought restrictions it made it impossible when I installed my pool. The PB was able to install a fill line for me that was hooked to a ball valve near my pool equipment. While this worked ok I desired the ability to turn on/off the fill line from my Jandy PDA remote. Well this past November a freeze forced my hand and my ball valve split in two. Even though the PB insulated the above ground line the freeze managed to get to the valve and crack it. I was worried this would happen again so I decided to bury the valve and plumbing in the ground. I also decided that I would try to add an automatic valve to the system so I could turn on and off the water with the valve. So after about an hour of digging and several trips to home depot I had a new Rainbird irrigation valve installed and a shutoff ball valve all underground. I also ran wires from the rainbird valve to the Jandy panel at the same time even though I didn't know how it worked and I didn't want to mess with it in the winter because I didn't have time on the weekends and it got dark before I got home from work. So until this summer I was just filling the pool by turning the manual override on the rain bird.
The Investigation:
So now how do I hook this stuff up? I took out a multimeter to the controller knowing that the rain bird valve needs 24V VAC. I figured I would turn on/off my bubbler which is on a JVA to determine if the voltage was compatible and it was. The white wire (leftmost) is 24VAC when the JVA is ON, the red wire (middle) is 24VAC when the JVA is OFF, and the black wire is the common. So I knew I needed to connect the two outside wires to the valve. Now the question is how to get the same 3 pin push on connector. I brought several home from work but they were all slightly the wrong size. Then I found out the part number for the Jandy part for the connector only (the darn JVA cables are ridiculously expensive I was going to buy one but for $50 it seemed exorbitant).
Parts Needed:
1 Irrigation valve (I used rainbird). Make sure it is 24VAC.
1 Jandy 2711 connector
2 Wires
Total cost for me was about $25 dollars
Install:
1. Install the sprinkler valve
2. Hook up the two wires to the two wires on the valve (color doesn't matter)
3. Press the two wires into the 2711 connector on the outside of the connector. Make sure they make a good connection.
4. Press the connector into an available AUX port.
Configuration:
1. Assign the aux that you connected to your sprinkler valve to an JVA. I assigned AUX5 to RETURN. MENU->SYSTEM SETUP->ASSIGN JVAs->{JVA NAME}->{AUX}
2. Label the aux that you connected your valve to FILL LINE. MENU->SYSTEM SETUP->{AUX}->GENERAL LABELS->FILL LINE
To use the fill all you have to do is go into equipment on/off and you'll see the FILL LINE listed. Even nicer is the Jandy knows to shut it off after 30 minutes because of the label.
Backstory:
The Investigation:
Parts Needed:
2 Wires
Install:
Configuration:
