Did I just make a mistake - instead of the Swimming Pool Muriatic Acid (14.5%) I got the other stuff, 31.45% - poured some in the pool - one box says Balance on it?
HDX 2 x 1 Gal. Swimming Pool Muriatic Acid (2-Pack) 10014HDX - The Home Depot
The HDX 1 Gal. Swimming Pool Muriatic Acid (2-Pack) is ready for use and does not require mixing. This pH reducer is designed to help prevent scaling caused by calcium-based chlorine and hard water.
www.homedepot.com
