Hi. This is my first month of usage with a brand new tub and it has increased my energy usage by 870kw. Yep you read that right. It's a Tuff Spas TT-250 hooked up to 220v with Full Foam and I paid for additional "Extreme" foam in addition. I keep at a 103 and it is defaulted to two 2 hour filter cycles per day. We use it every day for a half hour and run one 15 minute jet cycle while using. I think an inflatable hot tub would perform better. When I looked inside, at first it looks well insulated with spray foam. However, upon further inspection, there is almost no spray foam on the shell itself. It's like they just opened the panels and sprayed the components, but not the actual shell. While I had the panels off, I filled all the gaps with insulation and that appeared to have an immediate impact. But, needless to say I am really concerned and unimpressed with the performance of this hot tub....especially since the dealer said, "You're looking at $60 per month at most to run in the winter."
