Hey guys, I am again left scratching my head. Not uncommon. I am trying to generate a TDH in feet based off the readings from my pressure and vacuum gauges. But the number I am getting is no where near the performance curve (to figure out my flow rate) so I must have done something wrong. I am using the calculation: CALCULATE TDH - Multiple the Vacuum gauge reading x 1.13. Multiply the Pressure gauge reading x 2.31. Add the two products together to determine TDH for your system.
It is possible I am using the wrong numbers on my gauges as there are two set of numbers (one reading is bar and the other psi) so perhaps that is where I am messing up? Here are some pictures to show the readings I have at 1500 RPM. I plan on doing all of the RPM curves listed for my pump but if the first time I did this I got an odd number I am wondering where I have gone wrong. I used basically 8 and 8 for the vacuum and pressure gauge readings. That brings me to roughly 27. So on my gauges do I use the black number reading or red? The pressure gauge is the one with the black housing and the vacuum is silver. Thank you for the input!!!!
-Luke
-Luke
