Hello all, long time reader, first time poster. Thank you all for the past guidance which has gotten me this far.
I am looking to replace my Single Speed WhisperFlo 1HP (WFE-4) pump with a more efficient and quieter VS pump. The pump is located directly beneath my bedroom window (which I cannot change) so I would like to place a premium on noise level.
Thank you in advance for all of your advice, it is much appreciated.
-Chris
- I have a 15,000 gallon pool (no spa) that I only cholorinate with liquid chlorine, only heat with a pool cover, and only clean with a robot not with the pump. So my only "pump mode" is filtration, so I think I will be using lowing RPMs almost all the time, maybe modifying slightly during summer vs winter to increase number of turnovers.
- I have solar power (not solar water heating) installed so my cost per kWh is fairly low. I need a VS pump because I am currently using more power than I produce and 5-7kWh per day savings would flip that equation which is highly desirable.
- I already have the pump wired for 240V service and I will be buying the pump online and installing it myself.
- Lastly I don't mind spending money on a pump that will save me money later, but I don't want to spend money on a pump with features I do not need for what a pool that I think is a "simple" use case.
-Chris
