I have a new Pentair SD60 sand filter and multiport valve. I'm unable to get the multiport valve to sit flush to the lip of the tank. There is about 1/4' gap. If I take the o-ring off it sits flush, so I know te stand pipe is in the correct position.. I have applied lube to the o-ring and to the inside of tank. Anyone know what I can do to get this thing on?
I have a new Pentair SD60 sand filter and multiport valve. I'm unable to get the multiport valve to sit flush to the lip of the tank. There is about 1/4' gap. If I take the o-ring off it sits flush, so I know the stand pipe is in the correct position.. I have applied lube to the o-ring and to the inside of tank. Anyone know what I can do to get this thing on?
