Help!
Houston, Tx. (FULL SUN FROM 11am to sunset) 25k gallons, Altima Plaster blend. Spa/pool 3.5 years old. Jandy system.
Last summer started noticing mustard and black Algae. Hired a Pool guy who cleared up the mustard, but not the black. After 2 months of no improvement I went to Leslie's and they recommended a copper based algaecide and told me to put a cul-lator pack in my skimmer. Boom, Black algae was gone! Over the next few months the walls were stained turquoise then the dark staining began (mostly on the spa walls and the pool steps/seats) . Fast forward to last week. Current pool guy used Natural Chemistry Stain free extra strength followed by NC Metal Free... no change.
I took a water sample to Leslie's and my Copper was 1.5 ... drain pool recommend. We drained 3/4 as we have had rain and I've heard stories of pools lifting out of the ground. Re filled pool and done by 11am this morning. Ran the filter for an hour and took sample back up to Leslie's. Copper now at .5
Recommendation was once again Stain Free, then 1 hour later metal free and run for 24 hours. Then clean filters and begin to add chemicals and
stabilize.
1st pic water test after refill
2nd pic - spa before treatment (you can see slight metal staining, and debree)
**dumped the Stain free around spa and perimeter of pool.
Minutes after adding Stain free ledges, seats, stairs turned a red rust color!?
Called Leslie's immediately, guy said he's never heard of it before, but just give it time...
Then after an hour (and several times brushing) it turned dark, almost black
Now 2 hours post Stain free... metal stains (had mostly in spa) haven't budged and the staining from the Stain free powder is still there, just looks lighter but more grey.
**Is this normal?? Do I need to follow with the METAL FREE now or do something else.
