Hello. New to the forum and would like help on correctly wiring up my first Pentair Easytouch 8 panel.
Equipment needing hooked up: Ultratemp Heatpump, filter pump and (3) Globerite color changing LED lights. One of the lights is a bubbler light and they are all coming on at the same time for now.
Panel is fed from main house panel with a 90 amp 2 pole breaker.
What I think I understand from the Pentais manuals.......main feeder wires into the lugs on breaker busbar........ 1): Filter Pump: Wires from 2 pole 20 amp GFCI breaker for filter pump to relay marked 'FILTER PUMP', from pump relay out to pump......2) Heat Pump: wires from 2 pole 50 amp breaker for heat pump to special purpose relay marked 'ELTC HTR' then from relay out to heat pump. Also looks like I need a cable from heat pump control board to the Easytouch panel? Not sure type and how many conductor cable needed and what termianls to hook to on each end.........3) LED lights: from single pole breaker a hot and neutral to switch or IntelliBrite Controller (no neutral connection at switch, just passing through here) to 120 volt side of step down transformer. Cords from the (3) lights go into the low voltage side of transformer. Wiring diagram in transformer box says the orange is the common which I assume I will tie all (3) white wires from each of the lights to and the black wires from the lights to the wire color for 12 volt.........4) EasyTouch Transeiver: mount somewhere near the panel and connect the (4) conductor cable from the Transeiver to Comport (J20) in the panel.
Any input / clarification is appreciated. Also if someone has or can draw a line diagram on how all this equipment gets hooked up would be huge.
Thank you!
Thank you!
