I typically use a 4.25 HP shop vac but for some reason I cant get the main drain to blow out. I tried everything do you think I just need a larger HP vac.My compressor does not seem to produce enough air to get it to bubble. The pool ones are too much money for 10 mins a year. Any help will be appreciated.
Drain is in about 9' water
