Heater troubleshooting
sktn77a
2,926
Chapel Hill, NC
I have a 10 year old Jandy Lite 2 LG millivolt heater. Pilot lights fine. The main burners have been failing to turn on intermittently when I push the ON switch. I followed all the troubleshooting steps and the only odd thing is all the voltages are low. Where it asks "Is voltage 200mv+?", its about 150 mV and where it asks "Is voltage 500mV+" it's about 350-400mV. As the replacement gas valve is $400+ and the replacement temperature control is $200+, I don't particularly want to throw parts at it, especially as I'm not convince either is the problem. What generates the voltage in these heaters? Maybe that's the faulty component?
A millivolt pool heater will not operate with only 350-400mV. It takes that much to run the whole system (typically 400), but with everything running there should be at least a 100mV reading left over. Its that "extra" that keeps the system on. New pilot generator time. Even a new generator will take a bit of time to get a full reading and will seldom ever read the full 750mV they are rated, usually about 700.
Yes, I was thinking along those lines based on the troubleshooting I did. Fortunately, I have a thermopile that I bought a couple of years ago after I had the local pool repairman to come out to replace one..... $400!!! Admittedly, he spent over an hour checking the voltages before he diagnosed the issue and replaced the thermopile. The question is how to get at it without disassembling the gas supply to the valve. I'll check out the YouTube videos, above.
Burner tray has to be pulled out to install the generator, sorry.
Following up on this thread from last year. I managed to struggle through the summer last year but this year, absolutely nada. I had a feeling that there might be something going on with the on/off switch or the temperature control. Jumpered the on/off switch to no avail. Jumpered the temperature control rheostat and bingo - heater lights every time now and stays on until I turn it off from the on/off switch.
So right now I'm happy not using the temperature control (it was always on Max anyway), and just turning the heater on/off when I need to.
