I have started the plumbing for by-passing the heat pump but ran into a concern. According to all instructions the check-valve should be at the lowest point of the plumbing. This is not quite possible for me because after the heater the returns then run underground. Will the check-valve work anyway? My plan was to put a 90-degree check-valve to the heater output attached to a 2" Y. I would then run a 45 elbow to the 3-way diverter and attach that to the Y.
My other option would be to attach another 3-way diverter to the heater output and other diverter.
I think the reason I like the check-valve better is because it may be simpler to use and only having to turn one valve.
Any thoughts?
Thanks
Daren
Any thoughts?
Thanks
Daren
