I am new here, and the first thing I need to do as a new pool owner is fix the valve coming out of the filter. Right now, no matter what setting the valve is on, water comes out the backwash port. The pool guy that came out to take a look said these types of valves are difficult to maintain and suggested I replace it with a push/pull valve. Some commenters here said that's maybe not the best idea, so I did some reading tonight, and it seems like they are actually fairly easy to repair or replace, and possibly don't even cost as much as he said it would (his SWAG was ~$350). It seems like the common issue with this is the gasket, and just getting a new one might fix the issue. Worst case scenario, the whole top section of the valve needs to be replaced, again, seems fairly simple. What would you fine people suggest? Here is the valve (I can get other pictures from different angles if it helps):
