I can't find the answers in the manual or on the web:
What is the pump counter counting in "low temperature operation, press resume to cancel" It went into high-speed mode and displayed 7:21, 7:20 one day. It was displaying 4:20 on the second day. It started around 10pm on both days when it got cold. The main wall controls are in charge of starting and stopping the power to the pump, not the pump timers. Same for freeze protect - main wall unit, not the pump.
The weird thing is that I disabled the freeze operation in the pump settings, but it still went into the same low temp mode on the following day. But, seems to have finally worked on the third cold day as intended - main unit turned it on and the pump went into the usual moderate speed after priming.
Last thing - seems that the only way to set the pump to "always on at constant speed" is to go 12:00 am to 11:45pm in timers. Does it shut off at 11:45pm for 15 min if the power from the wall board is still on? I know I can just stay up and see what happens, but it's too cold to be messing with this in the dark
Tnx,
Tnx,
